'87 notch project
the quad shock brackets are all gone now, going to build the new dash and assemble the heads tomarrow night. have a big list of things that we are going to be working on tomarrow. should finish the mini tubs and start the cage by sunday night!!!
Lookin good. Car looks great in person. Can't wait to get my car over to your place to have you start your magic on it. Order a front airdam for my car on Sunday, tryin to make sure I have all of the parts before I bring it over to your place in June/July.
tires are mounted and the floor plates are bent for the main hoop. i should start welding tomarrow! should come together quick now...
also i have a bet going now that it wont run in april so... time to "get r done" and win some money...
toying around with some diffrent ideas for the rear suspension just to get it on the street soon. ran out of funds and still need to get the parts for the rear suspension...
Did you get the distributer?
yeah i got it... thanks again. now i just have to swap out the gear on it.
the short block is most of the way done. had issues with my ring compresser, then more issuses with the oil pump not clearing the girdle, missing bolts, and the pickup didnt want to line up. now the oil pan is slightly off center due to clearance issues with the girdle... it will be all fixed and bolted, sealed up before the weekend. then back to body, interior, and electrical work...
shortblock done. going to have around 8 hours or so to work on it tomarrow. got a few small things to do to the cage and have to add the dash bar. might paint it tomarrow.
