aimmotorsports
well i posted my project in annother thread, but, here its is when i first bought it. it has some things done, not much yet. heres a list:
ECU is MASS AIR from a 89.
306 (short block) when I bought it (4K miles on it, give or take).
Stock 351W heads off of a 1996 E250, And the cam from that engine which was a LOW milage engine (roller)
Brand new lifters (stock rockers)
BBK cold air intake to fender
MSD 6A.
blaster 3 coil
March alternator tensioner.
BBK underdrive pulleys.
Ford racing plug wires
stock headers
older O/R Hpipe
Stainless tailpipes (need a polishing)
currently older Flowmaster muff's.(I have brand new Thrush 2 chambers and (new) stainless flow tubes to go on)
Jegster upper and lower control arms. And poly bushed in the axle. (8.8)
New rear shocks. And what I think are some aftermarket springs.(grey)
CenterForce dual friction clutch with matching pressure plate.
Ford mini starter
Pro 5.0 shifter with stock handle (and the orginal Pro 5.0 handle)
fuel pump is a year old (I dont know if its a stocker or larger)
Pony wheels with good tread all the way around.
Front and rear GT swaybars.
Stock upper and lower intakes.
BRAND NEW HEATER CORE.
Rear brakes are all new.
Traction Lok works great.
Firewall adjuster for the clutch.
Manual windows
Clean! doors, hood and trunk lid.
LX front seats (not currently in the car)
Alpine CD
Subframe conectors (welded on)
and as it is right now.
MSD 6A.
blaster 3 coil
stock headers
older O/R Hpipe
Ford mini starter
Manual windows
Alpine CD
