Got the 460 at the builder's here are some of the part's that are going in there. The block is a 1973 Dove A2A, The heads are reworked stock cast iron SCJ heads, I will have flow chart on them soon They flow a ton :spank:
Looking at a little over 600+HP & well over 600 Torque at the crank. Oh the crank that I will keep to myself for a while all I know is it's a stroked Eagle forged job.:headscrat
Fox Body oil pan and pick up
Double roller timing chain
Ford Racing rod's
Clevite 77 bearings
Dished piston's offing these and going with .060 over Forged Flat Top's, That will bring me into the 11.0:1 CR 97octane+ pump gas
The Header's
The Cam
The cam spec's
grind # f-286/3765-8
valve setting: intake .026 exhaust .026 Hot
lift: intake @ cam 3765 @ valve 644
exhaust @ cam 3765 @ valve 644 1.71 rocker arm ratio
cam timing @ .020 intake opens @ 57 deg BTDC closes 85 deg ABDC advertised duration 322 deg
exhaust opens @ 93 deg BBDC closes @ 49 deg ATDC adver duration 322 deg
spring requirements dual part # 99893
loads: closed 120lbs @ 1.875 or 1 7/8
open 355 lbs @ 1.282
Cam timing @.050 tappet
intake opens @ 40 deg BTDC
closes @ 66 deg max lift 103 deg ATDC duration 286 deg
exhaust opens @ 76 deg BBDC
closes @ 30 deg ATDC max lift 113 BTDC duration 286 deg
recommended rpm range with matching componets
min rpm 5000
max rpm 8000
valve float 8200
