352" Dart based SBF blower motor
Rubbernuts
8.2 deck Dart Iron Eagle Sportsman block-4 bolts on center three caps
4.060 bore
Cola/TFS 3.400 forged crank
Eagle Armour Guard H beam rods-ARP 2000 rod bolts
Diamond -7cc dish pistons-HD thick wall wrist pins-motor is 9.0:1 compression
Hellfire rings-3/16 3/16 1/16
Clevite rod and main bearings
Dura bond cam bearings
DSS double roller timing chain
Comp custom solid roller blower cam
GS Ultra Pro solid roller lifters-.875 diameter-intakes offset
Cometic .040 4.155 head gaskets
Smith Brother custom push rods-3/8 diameter
Canton 7 quart pan and pick up-has bung welded to it for blower oil return
Innovators West crank trigger balancer, pointer and trigger sensor
JW Wheel flex plate-out of date
Ron Sharp TFS 225cc high port heads-2.125/1.625 stainless valves-Manley NexTec springs-Tit. retainers
Jesel 1.6 shaft rockers
MCRP valve covers with breather tank bungs welded on them
Edelbrock Super Victor intake, converted to EFI-MCRP intake gaskets-w/fuel rails
Accufab throttle body and elbow
MSD crank trigger distributor
MSD spark plug wires
Ford 1992 high torque starter
Skinny Kid front and mid motor plates
Factory timing cover
Motor has 5-10 passes on it since being freshened by MCRP. Crank, rods, wrist pins, rings, bearings and gaskets are new. Motor has been 5.15 140 1.24 60ft on a 275 pro at 3280lbs, with a Xi cast wheel blower, with more left in it.
$13,000 obo Will separate short block and heads.
If interested, text is best way to contact me 517-605-0373. I can text pics also.
Thanks, Scott
