351W Part out and 347 shortblock
fastford
351W high compression shortblock: TRW forged pop ups, D4 block, ARP main studs, O-ring'd decks, hi-vol oil pump, ARP oil pump driveshaft, 1500 miles, new damper, cast iron flywheel, clean and ready for final assembly $1850
Dart Windsor Senior Heads, stock big combustion chambers (I was trying to cut down CR on above shortblock), 2.02"/1.6" stainless valves, hydraulic roller springs, ported by Thompson Automotive, 7/16" screw-in studs and guide plates, fresh valve job, clean and ready to bolt on $1100
351W MSD Windsor distributor with bronze gear (1500 miles) $150
351W Edelbrock Performer RPM intake (port matched, ready to bolt on) $175
Motorsport 351W fox oil pan w/dipstick and tube $100
351W fresh alumicoated shorty headers $200
Motorsport 10-1/2" clutch and p.plate (new) $150
302/351W Carter Hi-vol mechanical fuel pump with aeroquip fittings $50
March steel underdrive pulleys (new in box) $85
302/351W double roller timing set (1500 miles) $40
Trick Flow 1 piece pushrods (351W HR application) New $85
302/351W Scorpion 1.6 ratio 7/16" roller rockers $180
302/351W Motorsport tall aluminum valve covers $50 (breathers loose)
302/351W front cover with mech fuel pump provision and new Rev rotation water pump $75
ALSO, 2 fresh built shortblocks
347 - Speed Pro flat tops (10:1), Eagle I-beam rods, Eagle cast crank, Clevite 77 bearings, Roller block, C-4 small flex plate, Power Bond damper, fresh machined and assembled $1850
351W - built for boost, SRP dish pistons, Eagle H-beam rods, ARP main studs, D-4 block, Clevite 77 bearings, fresh machined and assembled $2200
