331 built for boost
fastford
Brand new Shortblock $2900
331 CI early 289 block, acid cleaned and furnace burned, shot blasted, block is better than new, bored and honed with deck plates, align honed crank journals, clearanced for stroker, machined for 1 piece rear main seal and ½" head studs, square decked
ARP main studs, windage tray
4.030" bore, 3.25" stroke
Scat 4340 forged steel crankshaft
Scat 5.4" H beam connecting rods
Probe SRS forged dish pistons with in-line and TW valve reliefs
Ford Racing damper
Cast iron flywheel and AOD flex plate
Balanced rotating assembly
World Windsor Sr heads $800
Ported by Tompson Automotive
2.02"/1.6" Manley severe duty swirl polished valves
Comp Cams hydraulic roller spring, retainer, keeper kit
Comp valve job
7/16" screw-in studs and guide plates
Additional assembly parts and complete assembly/start-up available
ARP head studs
Gasket kit
Scorpion roller rockers
Crane cams link bar hydraulic roller lifters
Ford Racing billet multi-index timing chain set
Front cover
Water pump
Canton 7 quart pan
