i changed the ignition switch it worked after that for a day then the same shit im thinkin a relay somewhere ? hoping someone had this problem before its a guessing game ???
i checked the fuses and went thru the relays under the hood did ignition switch took the battery and tray out to check for coroded wires it all seems fine and clean so you say check under the fuse box for coroded wires ? im also going to look at the wires connecting to the ignition switch
Print a schematic and use a volt meter to check the contacts under the relays. See if one has a bad power or ground.
As stated it's usually a problem with the power distribution center under the hood, easiest way to check is to turn the acc. on and go hit or shake the box.
integrated power modules and smart junction boxs are fun
i asked because i fixed a few wire issues on ram, dakotas ect. few explorers too.
The wires on the column would break or come loose due to the tilt being used everyday.
i looked under the fuse/relay box all wires seemed fine dirty thats about it so i started to test with my test light and i put in one of the relay prong holes and when i put it in the heat started to work i was also wondering why there was no relay in that spot in the first place ??? any ideas
