91 GT AOD
So the current problem: Sometimes the car is fine, for extended periods of driving. Other times, it just dies, and you can hear the fuel pump going on and off a few times. Before this, I found the ignition coil was wired to be on 24/7, and the way it was grounded was shorting out the computer. That has been fixed, but the same result is occuring at random times. I drove from 10/Groesbeck to 8 and Telegraph, and then from 8 and Telegraph to Downtown Rochester with no problems. When I went to leave work later in the evening, it was dying just after starting it. After about 6 times trying to keep it running, I said screw this and called U WIN. After they towed it to my repair facility of choice, I started the car and it fired right up, no problem. Let it run for 20 minutes, no issue. Basically I'm at the point where the problem is too intermittent for me to know whats wrong, and my mechanic is too busy to spend all day every day trying to replicate the problem. He had a few ideas of parts I should replace, but I'm curious if anyone on here has had a similar issue, and if so, what fixed it for them.
PS - Everything from Power wire off of the battery, terminals, Ignition Coil, Cap/Rotor, Plugs, Wires, etc have been changed so far. I'm thinking maybe bad relay, or computer on its way out? I'd really like to get this thing 100% right, as I would like to sell it, but I won't sell it unless to the best of my knowledge that its in 100% working condition.
Thanks a bunch Motown, I'm sure someone has an answer.
