2003 Navigator Air Ride Problems PLZ HELP :(
Chances are good that it's a standard relay available at any parts store. Pull it out and take it in. They'll have them.
Trying to find a fuse box layout so i can pull the right one, dont have the owners manual so i dont know which relay controls what
should be labeled on the under side of the fuse box cover.
Or if all else fails listen and follow the noise. Put your hand on the relays, you'll be able to feel which one is clicking.
relay is at the right front of engine compartment, mounted to the compressor bracket , early production is solid state , late production is electro mechanical
powered by fuse F1.111(50A) behind the right kick panel(early), F1.11(10A) and F1.111(50A) late
the early/late break is feb 3, 2003, check the door tag
