trigger
After much debate I have decided to sell my formula firebird project car. I was in process of setting up the motor plates / mid plate and finishing the cage work (8.50 cert).
Here is the breakdown of the car –
2000 formula firebird
Burkhart BBC motor plates – not installed
Burkhart midplate – not installed
Burkhart powerglide crossmember
VFN 5” sloped extended hood – no fasteners installed
VFN dashboard – not installed
6 point mild steel rollbar
Kirkey seat
Madman seat bracket
Wolfe torque arm – needs crossmember made/ordered
BMR LCAs rod ended
CE rear shocks
QA1 single adjustable fronts w 315 spring
Automatic pedal assembly
Stock case powerglide with transbrake
B & M pro ratchet with carbon fiber cover
Derale trans cooler with fan for remote mount
3 gallon fuel cell with custom bracket for hatch mount
A1000 fuel pump
Aeromotive carb regulator for A1000 setup
Moser housing 9” narrowed 3” per side. Drain and fill installed. Backbracked
35spline moser axles, 5/8th studs
Nodular center section
35 spline pinion setup
Mild Steel driveshaft for 9”/powerglide setup
15x10 5”bs Weld Magnums
15x3.5 Weld Magnums (2 piece)
Strange rear brakes single caliper
Burkhart parachute mount
Custom made headers for bbc/4th gen car. 2 1/8th primary stepped to 2 1/4th bullet style exhaust off the collector. Headers are coated.
NX direct port can also go with it. 15lb NOS bottle
Random stuff that can go with the car
Stock radiator and fans
Ls1 shortblock with arp rod bolts
Yank th400/ls1 converter 5000rpm
Stock coils, msd wires, etc.
ANYTHING LS1 I have laying around
I would like to get 7k out of the car, or I would trade for an automatic equipped mildly modded ls1 car or mustang.
Kirkey seat
Madman seat bracket
BMR LCAs rod ended
CE rear shocks
A1000 fuel pump
