Superman09
We sold the building I am currently using and with my current Autorama Trans Am project, I am unsure if I will get to finish the set-up. The sleeper set-up was just going to be used this year and I already have someone who wants to use the roller for a more drag only set-up as it should be!
Here is what I have for sale!
1999 LS1 engine
-SOLD
1998 LS1 engine
-SOLD
4l60-e Transmission (Fresh from Detroit Gearbox)
-SOLD
Circle D Pro Series Multi Disk 3C Converter
-Ran in my Trans Am last year. Just sent it back to Circle D to have it cut and cleaned. It is fresh and ready to roll, never been ran or used since being cut and cleaned by Circle D. It is a 3C (3500-3700 stall speed triple disk) For all the info check it out here: http://www.circledspecialties.com/p-17-gm-245mm-pro-iii-4l60-ls-torque-converter.aspx
$900
PA Racing Body Mounted Tq. Arm
-Black powder coated. Built to mate to a stock rear end. Ran in my Trans Am last year. Comes with Tq Arm and chassis mount.
$300
60# Siemens Deka EV1 Injectors
-Used in my Trans Am last year. No issues when pulled, worked and flowed great!
$275
Brand New Magnaflow Catback for 98-02 LS1 Car. Brand new, never been bolted up or installed. All hardware included. Dual Single tips.
$450
LS6 EGR Equipped Intake Manifold. Fuel Rail, injectors, and TB NOT included. Intake only.
$335
LS1 Water-pump.
$50
LS1 Power Steering Pump. Couple chips in the pulley but no issues. (Fittings for the aftermarket PS lines not included) Can include the Power Steering line kit for $145 however.
$50
LS1 Starter.
$30
LS1 Clamshells with Poly Mounts installed.
$75
Will get pictures up ASAP. All prices are picked up, cash only. Thanks!
1999 LS1 engine
-SOLD
1998 LS1 engine
-SOLD
-SOLD
$900
$300
$275
$450
$335
LS1 Water-pump.
$50
$50
LS1 Starter.
$30
$75
