'00 GT Project
Starting the next step
BW s400-75
New heads are here
Should be a fun ride come spring:devil:
Here is the turbo mount. It's built out of 3/8" so it isn't going anywhere ;)
It still gives clearance for the downpipe with the truck accesories but I am putting Camaro waterpump and relocating the alternator to the pass side
Going to try to work on the hotside this weekend as I have all the parts (minus the WG that was ordered today)
Finished up the passenger side
Still need to order the pipe for the wastegate which should be in quickly and to get the downpipe done
I got the f-body waterpump and still have to swap the balancer out which will be done when the cam is installed
I only worked on it a little over the weekend
Work had our Open house on Saturday so I only spent a few minutes working on the car
I got the wastegate merge tied in what appears to be the best spot I could put it
The downpipe material will be here tomorrow so I should be able to get that finished up and then I can get the pipes out to be ceramic coated.
I got the rearend back so that needs to be put in and then order a few more parts and hopefully it is running sooner rather than later!
