WTB: 5.0 water pump pulley (and other stock parts)
Ozz
WTB: stock 5.0 parts
edited 3/12
Looking to buy all sorts of stock 5.0 parts, for years ranging between 86-95.
Interested in the following, possibly other similar parts as well:
86-93:
- alternator bracket
- PS pump bracket (and smaller mounting brackets)
- AC compressor (working, of course)
- AC mounting brackets (both large and small)
- IAC valve
- belt tensioner
- hood latch
- hood hinges
- throttle cable bracket
- timing pointer
- oil sending unit block extender (45 degree end)
- heater core tubes
- timing cover
- EGR valve (round body/square mount)
- waterneck/t-stat housing
- intake plaque
- PS pulley
- water pump pulley
94-95:
- PS bracket
- pulleys (any, OEM size and not underdrive or aftermarket)
- CCRM bracket
- belt tensioner w/idler pulley
If you have any, all, or multiples - post up!
Anybody got a stock water pump pulley kicking around? Preferably somewhere close to Canton so I don't have to drive too far to pick it up...
I'm also looking for other stock parts such as component brackets, pulleys, accessories like IAC valves and belt tensioners, and other misc. parts from the 86-93 5.0 engine, so feel free to speak up if you have those too.
i got a waterpump with the pulley
I just need the pulley, I can't imagine you'd sell the pair for what the pulley alone is worth to me. Would you split them up? I have 2 extra water pumps sitting here and the only extra pulley I have on hand is larger than stock. I think it came from a Thunderbird.
TTT updated list:
edited 3/12
86-93:
- IAC valve
- belt tensioner
- hood latch
- hood hinges
- timing pointer
- heater core tubes
- timing cover
- intake plaque
- PS pulley
- water pump pulley
94-95:
- PS bracket
- CCRM bracket
Can't use any of that, but if you have the bracket for the alternator I could use that.
i have an entire pulled engine from my 93 sitting at work. It had a "Cobra" intake plaque on the stock intake too.
That must look funny ...
If you're interested in taking parts off of it, I'm interested in taking them off your hands
TTT - looking for more of the same stuff again. I know I talked w/a few people before that we never ended up making a deal. If you're still out there, have the parts, and are interested please get in touch!
