Musmaro
My welder got stolen last week so I need to buy another one. Wirefeed mig. Doesn't have to be fancy, gasless will work for me. Just needs to get the job done. Cheaper the better.
Also I really need an AOD flexplate. Need it like now. Stock is fine, aftermarket would be cool. Just aslong as it is straight, in good condition and is a 164t with 50oz balance.
Other Fox Body parts I really need to get running would be:
-Trans mount, want a poly or even a solid if it will work with my stock motor mounts(unless someone has a good stock one that is really cheap)
-SBF Alternator bracket, March style preferred. will take stock but will need the tensioner aswell.
-C4 kickdown setup for a Holley four barrel, could use a shift kit aswell
-Underdrive pulleys and a belt for a setup with no smog and the p/s pump moved to a/c location
-H-Pipe stock will be fine but prefer aftermarket. Could actually use a complete exhaust(long tubes, x pipe and some mufflers with dumps would be perfect, 2.5" preferred)
-Good Power Steering pump OR pulley remover/installer
-Tall Valve Covers
-Points style plug wires OR cap adaptor to run new style cap/wires
If I think of anything else I will add it. I could use some other stuff to such as subframe connectors, torque box reinforcements, roll cage, 8.8 rear end with 3.55 or lower gears(five lug preferred), five lug front conversion, decent seats(racing seats would be good), rear lower control arms, poly crossmember bushings, nice ignition setup(obviously from above I am running a points dizzy for now), 1" plastic/phenolic sucker style carb spacer), and some other performance goods. BUT this stuff is not as important as what I have listed above.
Oh one last thing, I need a set of front axles for a 91 GMC 1500 4wd pickup and a bug deflector for a 99 Silverado.
Thanks for looking. I have everything listed in this thread http://www.xceedspeed.com/forums/showthread.php?t=102445 to work a trade with and also what I have in this album: http://s21.photobucket.com/albums/b291/Musmaro13/Stuff For Sale/
-Tall Valve Covers
