will 15" rear wheels fit on an 99-03/04 cobra?
Venmous28
i have cobra brakes on my rear axle. and want to run some slicks, can i use 15" wheels? or am i screwed??
hurry guys hurry..
its not bad when yo fit the wheel on there you will see were take prob 15 minutes per side right on the upper edge
Venmous28 said:
k... i checked on some other sites saying they'll fit fine, but ill believe you first.. thanks for the heads up
All tell you to be ready to grin a little, if you use a wheel weight on the rim in the front it will rub for sure a 10 requires grinding of the banjo bolt no materr what backspace is used.
Yes if its a 10 in out back you might have a problem rubbing thr banjo bolt to the brake line cause it will hit the rim.
