I've replaced the brakes 3 times and always vibrate. Do I need to spend $50 each on drilled/slotted rotors from tirerack to not get chinese garbage. I do alot of highway stops so 60-75mph
Clean the hub face of all rust and scale, 90% of brake and shake is cuase by the hub being rusty and distorting the rotor hat which in turn distors the rotor surface. Also making sure the rotors are properly finished before instilation is a big deal as well.
