Jacob
Ok,im building my first turbo car and will have everything I need in less than 4 more months---> On3Performance 70mm turbo kit,Wideband,fuel injectors and a Megasquirt standalone to tune everything..
Its a stock block so I plan on 500RWHP max and im sure the 24lb injectors aren't enough so what size injectors will I need?I don't wanna go bigger than I need but big enough to run a safe tune..
Also what about my fuel pump (Walbro 190lph),will it be good enough for what I want?Not sure if it helps but heres what the car has as of right now..
Stock block 302 (std bore),Edelbrock Performer 5.0 aluminum heads (ported),Trickflow stage 1 cam, crane 1.7 roller rockers,HD valve springs,Typhoon upper and lower intake (ported), Accufab polished 70mm tb and egr spacer, Pro-m intake/80mm velocity maf. Anderson motorsports 6 inch power stack air filter,Ford Racing 24lb injectors, Kirban adjustable fuel pressure regulator, Walbro 190lph fuel pump..
