riche Forum Member Jun 23, 2017 #1 Doing a 5 speed swap on my 93 feature. Car is stock drivetrain. What is a good clutch to go with for not a lot of $$$.
mustangmike6996 Club Member Jun 23, 2017 #2 Does Ford Racing offer an upgrade clutch? I know a lot of people used to run the king cobra. If you dont have a power adder then you shouldnt need to worry too much about slippage, more about pedal feel IMO.
riche Forum Member Jun 23, 2017 #3 yes ford does. $220 for it. Just wondering if there is anything better for less $$ http://www.americanmuscle.com/ford-racing-clutch-8601.html
The Man Club Member Jun 23, 2017 #4 that seems like a good deal.... doesnt Valeo make these for Ford? If your looking for just OE replacement, maybe check out Ram, Valeo, and definetly check out Rock Auto....they have a ton of kits for cheap. https://www.rockauto.com/en/catalog...8,1134076,transmission-manual,clutch+kit,1993
mustangmike6996 Club Member Jun 23, 2017 #5 $200 isn't bad for a pressure plate and clutch disc. Centerforce is around $400-500
riche Forum Member Jun 23, 2017 #6 Probably going with just stk replacement now. 3550 trans is going into my blk 92, stock t5 from that going into my 93 yellow which is stock.
S sofa king Forum Member Jun 23, 2017 #7 Ford Racing, or Ford Motorsport clutch Oops, yes, the one you posted is a good one.
OldbutNew Club Member Jun 25, 2017 #8 I went with an Exedy Stage3. Rated for 400 Hp. I think it was under $200 on E-Bay.
