what camshaft for stroker?
stanggt
I am building a 420 stroker and need a camshaft that works well N/A as well as running NOS at the track. Target compression is 12 to 1 with set up I currantly have. I have CNC'd 220 aluminum heads, Victor intake, will be a c4 with brake and stall still needs to be determined. 4:10 gears with 28/14.50-15 Hoosier quick time pro tires, either a plate system or fogger. Car should weigh about 2900 with me in it. any good used camshafts out there I can buy or who should I have cut me one for my application.
Thanks,Chris
Solid roller. 110 lobe Sep with the combo you want to go with. Far ad duration and lift I would say around 270/280-670/680 range at .050! Camshaft plays such a huge roll when it comes to performance. You really need to talk to comp or bullet etc. Need to know what your heads flow-carb size-header dia.-convertor-etc. Camshaft is were you do t want to over look if you want to get the most out of your engine
I have a custom grind from (Isky) from my 408. Nearly exactly the same as what Fogged10 suggested. Pm if you're interested. I am only looking for $150 for it, 10 passes and 100 street miles in excellent condition.
