John Boschma
the pump is sold, but the filter and fittings are still for sale $75 shipped.
this pump is a better pump then the earomotive A1000 pump.
Maximum HP:
1100 hp Inj/1300 hp Carb
GPH/PSI Range:
135 GPH/0-95 PSI
Consideration:
If your actual horsepower is close to the Max HP limit and/or you are considering a power adder, see part number DB2025-A
Features
Extremely quiet
Smooth, precise fuel delivery
Extremely low current draw
Self Priming
- Pump may be mounted above fuel cell
vertical or horizontal mount
All internal wear components are 100% metallic
No plastics or composite materials are used in the 1100-A pump. This results in the longest lasting, highest quality most durable flow through pump available.
The housing is made from corrosion resistant 304 brushed stainless steel
Mil-Spec Clear anodized billet end caps with No-Leak seals and stainless steel electrical connectors
-10 inlet and outlet with leak free o-ring ports
6.25 lbs
Two stainless steel T-bolt style clamps included with each pump
Long life, continuous duty
Current Fluids
Compatible with Gasoline Only (not compatible with alcohol / ethanol based fuels)
also comes with the vortech inline 100 micron fuel filter and the -10 fittings as you see it.
Maximum HP:
GPH/PSI Range:
135 GPH/0-95 PSI
Consideration:
Features
Extremely quiet
Self Priming
6.25 lbs
Current Fluids
