Rebel Racing
Hi Guys,
For the last several months there has been some corrison on some of the spark plugs--we change them every other race. Last week when I set the valve lash I pulled the plugs and as I was bumping it over a very fine mist of water was shooting out of the plug holes on cylinders 1 thru 4 (Dart block 306). The gaskets are 3 yrs old and are a SCE Titan--basically a copper gasket with a rubber coating around the passages.
The rad level is down a bit but there is nothing in the oil at all. I'm guessing that once the motor comes up to temp then it is sealing up--possibly?? As long as I'm not getting water in the oil is is still safe to run as is?? I intended to change gaskets in November when we swap intakes. No planned races this season but would like to run a few T&T's if they will hold. Any thoughts??
