H.O. Driver
I have a small leak in my drain valve and I have a temporary fix on it right now. However since I have a manufactured home I have a 20" door I need to wrestle it out of and the new one into. Do I need to find a water heater that is manufactured home specific or can I squeeze a normal tall water heater in there? The one I would like to get is 21.5" wide. is that the width of the drum or is that the width of the drum and connections?
The water heater I found is the same price as the "manufactured housing" but the efficiency rating is way higher. 68% on the manufactured housing one and 92% on the one I want. The one I want will do 96 gallons the first hour vs 60 gallons the first hour on the manufactured housing one. I have a family of five and 3 full baths as well as a garden tub, so the more hot water it can do efficiently the better.
Sent from my D6708 using Tapatalk
