Wanted- Stock LS1 Parts
Fryguy302
Looking for complete, stock 241 or 917 casting LS1 Heads and Intake, must be good shape and must be cheap. Cash waiting.
Also looking for accessories, Camaro throttle body, etc.
what is stock from my 98 ws6? if they are what you need you can have them, they are off and just sitting at my shop. Im going to scrap them eventually but if you need them your welcome to them.
I have some 241's
PM Sent.
The 241s are the newer ones, the 98s won't work. Thanks though.
The only difference is a notch in the sealing surface, but you can't use MLS gaskets with the early heads.
Raj:
Let me know if you need that F-body alternator bracket(s). Also, I think you can run just the Fbody alt if you set up the belt path right. Ignore the notes in the pic. Keep the original tensioner location.
Here's a pic of what I was thinking. You should be able to use a front side pulley between the water pump and the Alternator, the pulley offset/bolt etc should be interchangeable between the front side drive and backside drive pulleys.
Unfortunately that won't work, I need the alternator on top, driver's side. Need it to work with or without the water pump, and won't have any other accessories.
How about a truck damper and alt bracket? If the tb gets in the way there ate solutiins with or without a wp..
on the capri I used the truck bracket and cut and welded it to lay more toward the driverside to fit it under a stock hood.should be pics on the build thread or I can email some if needed
