SuperStang90
Ok, Instead of making a different thread for all the crap I need I figured one would do the trick. I'm in the process of a major upgrade with the drivetrain and would like to save a little and buy some used stuff if possible. So heres the list..
-Fuel Rails, that will fit an EFI Intake for 5.0
-Fuel pump, external: Something that will support 1000+hp and E85
-Fuel lines, braided -8 return, -10 feed
-Fuel Regulator for EFI not a fuel rail mounted one
-Injectors: 120lb or 160lb
-Sumped tank
-Will consider a complete fuel system if someone has it
-Tial or equivalent Blow off Valve
-Large front mount intercooler 1000+hp capable
-17" Front runner wheels like Alumastars, Race Stars, ect
-Tie-bar hyrdraulic roller lifters for SBF
-Stud girdle for Scorpion 1.6 rockers, AFR head
-Fabricated Sheet metal valve covers
-8.8 Diff cover girdle
-Rear Suspension stuff, Adjustable lower control arms with spring perch, adjustable uppers (Preferrably the Team Z relocation uppers) Strange adjustable shocks
-Roll Cage Kit, 6,8, or 10 point
-Aftermarket ECU Holley EFI
-Need entire system, main harness, injector harness, ignition harness for TFI, 3 bar map sensor ect..
I will add more as I remember if there is anything else
-Sumped tank
