vortech pulley question?
You dont need a intercooler over 8psi, I had 9psi on mine people run 15-20 without them, maybe a meth kit if you wanna be safe. Its a s trim blower right you will over spin it befor 22pounds but iam sure you could get 15 outa it perfectly fine.
It is a new E trim. Vortech told me that the E-trim is a T-trim case with SC inners. It is made for mod motor cars. As you can tell, I do not know much about mod motors. lol I have a friend with a 98 cobra helping me out. He was running 14#s with a s-trim and made 465 to the wheels. lasted 3 months then bent a rod. He has a built short block that is low compression now. He lost a couple pounds of boost and put 430 to the ground now with the same pulley's. That is the range I would like to be.
You should make that on 10=12 psi and a good tune, I got a huge blower and made my numbers at 9psi real safe tune and pump gas
