RSpencer
Alright, I ordered myself a universal 3 inch H pipe kit and some Hooker Aerochamber mufflers for my 95 Z28. The H pipe portion looks damn good, however, after that, it gets a little hairy. I have 3 point subframe connectors and a chassis mount torque arm. This fucks everything up. I had to put the pipe in a press a flatten it out a little bit to get it to clear the connectors (yes, I realize this effects efficiency, but it appears its a minute amount). My mufflers are basically dragging the ground. If i stacked my hands on top of each other they would be close to hitting the mufflers. I am beyond discouraged at this point and need to find a way to make this work. I would not be opposed to purchasing a different type of muffler. What would the cons be of coming right off the H pipe with mufflers and having them sit basically at the end of the transmission? Thank you for any help you can provide.
