DarkoStoj
This is a 1967 Camaro. It has a 350 4 bolt main motor with world sportsman heads (2.02/1.6 valves and 200cc intake ports), larger cam, long tube headers with 02 bungs welded in for an 02 sensor, weiand 671 supercharger blower kit with dual edelbrock 600 cfm carbs. Carbs have been modded with larger jets/metering rods, larger fuel discharge nozzles, and high flow needles/seats, enderle roller throttle linkage, and have a polished aluminum carb bonnet. There is a mallory unilite distributor which has been recurved for the blower, 8mm spark plug wires, and an accel high volt super coil. It has Holley electric pump with holley regulator, extra electric pusher fan, autometer fuel and boost gauges. Black interior is in very good shape, original center console car, SFI 6" harmonic balancer, 3.73 rear gear with a posi carrier, subframe connectors, traction bars, air shocks, Borg Warner aluminum case Super t-10 trans out of a corvette(one of GM's strongest manual transmissions) with a hurst shifter (the shifter could use some adjustment, and there is some clutch chatter when taking off in 1st gear). The car was restored and had the rear quarters, rockers, and taillight panel replaced, but it was good work done by a body shop and has no rust now except for a little bubbling in the front lower corners of the doors, but its not through the paint. The car is not perfect and could use some fine tuning on the carbs, but I drive it everyday(motor always fires instantly and has been reliable for me), turns lots of heads, and gets more attention than any muscle car I've ever owned.
video
[ame="http://www.youtube.com/watch?v=IB2sgs_1JpY"]YouTube - 1967 Camaro blower, 671 blown[/ame]
$15,900
video
$15,900
