jtproudmarinedad
I am doing my subframe connectors and I have a few questions & concerns. I am going with through the floor connectors, I cut out the opening for the rear subframe & I removed the rear floor pan. There seems to be about an 1 1/4" difference in height and a 3/4" difference from side to side from front subframe to rear subframe. :headscrat Is this right and how do I correct the difference? For the connector''s I have a bunch of size option's to choose from I have 2"X2" 2"X3" and 2"X4" also have 1 1/2"X3" all 1/8" wall tubing. Which would be best suited? it will be seeing a lot of track time.
Thanks
JT
Thanks
JT
