Stumped on power steering problem.
DarkoStoj
I had this cooler laying around.
Its a Rolls Royce with a Dodge Viper V10 in a 2nd gen camaro frame with a Saginaw AGR power steering box.
I plumbed it in the return line with 3/8 tubing. The high pressure line is 8AN
I tried 3 pumps and they are all super noisy and blow power steering fluid out of the vented cap.
I see a lot of the coolers use the tube and fin style and not the reservoir style. Is that what's causing the problem?
Do I need to change the pressure valve in the pump?
I'm stumped.
Sorry do not know the answer to your issue but that combo Rolls. Viper V10 on F-Body chassis is sweet.. Did you put that together?
I heard about this car elsewhere online and it sounds really cool. I was hoping you’d make a thread here with some photos when you have a moment.
I had to read the first line a few times. That's a hell of a combo.
-8 is pretty large comapred to the 3/8 ID return. There is possibly a pressure buildup due to the size bottleneck.
If you have a 1/2" hose, try running that as a return or possibly using a smaller supply line?
It's tough to give a definite answer with pressure readings. The pump could be fine but the pressure valve could be sticking causing the issue. How long does it take to blow fluid thru out? Does it do it at idle in the resting position or just in turns? Is the pulley correct?
I'm just throwing ideas out.
Not sure if it’s true or not but I was once told there are differences in power steering pumps for rack and pinions and gear boxes.
The racks take less pressure than the conventional style do. You can use the style cooler you have, just make absolutely sure it is on the low pressure side. It sounds like you have it on the high pressure side of the pump. It sounds like there may be a restriction somewhere. Double check the cooled to assure it isn't clogged with bits and pieces or stuff.
If you are initially installing the rack, then make sure you have that plumbed correctly. If it isn't, then the rack will turn all by itself (usually to the left).
Just my .02....grr
In stuff like this, I would try pulling the cooler out and see if it is blowing fluid out the vent without the cooler. Gotta start splitting the dictionary in terms of where the problem lies. I wouldn't put it back in until you solve the problem.
-Geoff
is the cooler on the return side?
Just my .02....grr
The cooler is on the low pressure side. I wouldn't think there is a restriction since all the parts were brand new. It has a AGR saginaw PS box, all new cooler/lines, and I tried 3 different pumps.
I think I am going to tap the return port of the pump and run a remote reservoir. I noticed there was a lot of cavitation in the factory power steering reservoir.
how about an electric power steering pump from a Grand Cherokee?
I am really kicking around the idea of installing a electronic rack and pinion off a newer mustang or camaro.
I've had nothing but problems with AGR stuff.
Do you have a P-series pump on it? They're the ones with the integral reservoir where the whole pump is submersed in it.
https://www.pirate4x4.com/forum/general-4x4-discussion/153940-saginaw-tc-pump.html#post1679554
https://www.pirate4x4.com/forum/gen...-modifications-pressure-flow.html#post8621464
I have a factory P-series pump off a Chevy 1-ton van with hydroboost that I use to move the 44" tires on my mud truck, front and rear, and it does it on dry asphalt with both axles locked without hesitation. This particular pump is supposed to be the high volume one (supposedly a little north of 3gpm at 1300psi). I never verified it, but it is way better than one off a 2wd pickup or a G-body. It worked fine. I tried a ton of aftermarket pumps.
I had some weird problems similar to you. I ended up reducing the rate at which the pump spun to less than the engine RPM (instead of being overdriven) because of cavitation when inflicting stupid. I also had to replace all the return-side hoses to ones that could handle a lot of vacuum. I kept starving the pump because the return hoses would collapse which lead to lots of bubbles which caused the pump to overheat. These two problems were a side effect of the fact when I'm being stupid I usually hold the skinny pedal to the floor while operating the clutch and both steering ends. 3-4 minutes of doing this in a mud hole gets everything hot. Power steering pump always made it, a lot of clutches and axle shafts did not.
Later I drilled out the ports to 5/32" so I could get more volume and shimmed it so it produces 1400psi before blowing the relief. It's still a little slow when trying to move both front and rear at the same time, but it does it. The rear is a ram-only, the front is just ram-assisted. It made a moderate improvement with speed to steer but nothing impressive. I never ran a power steering cooler, but I had a lot more oil (two rams and all the hose to get to the rear steer).
