Steeda Parts BELOW COST Blowout
99SaleenSpeedster
We have an overstock on the following Steeda parts. Limited quantities available at these prices.
Steeda Sport Springs for 2005+ Mustang. Part # 555-8215
RETAIL - $259.99 ; SALE PRICE - $175.00 + Shipping
Steeda Mustang springs offer the perfect balance between ride quality, performance and drop. They will provide great handling and race-ready performance while still soaking up the bumps and cracks in the road.
* # Lowers the vehicle approx 1 inch front, 1 1/4 inch rear. The S197 Mustang sits high in the rear, these springs will give it a more aggressive look.
* # Maintains good ride quality for daily driving
* # Big improvement in handling and noticeable reduction in nosedive
Steeda Bumpsteer Kit 05-07 Mustang Bumpsteer Kit - Part # 555-8106
RETAIL - $159.99 ; SALE PRICE - $100.00 + Shipping
Correct Your Bumpsteer with this Bumpsteer Kit that features spherical rod-ends with tapered shafts for a hassle-free installation that requires no drilling of the spindle for fit. Recommended for all lowered Mustangs with X2 Balljoints and/or caster camber plates. Now available with a wider range of adjustment than other kits.
Definition: Bumpsteer is a change in toe* angle caused by the suspension moving up or down. Bumpsteer is built into the geometry of the suspension and steering system, and has nothing to do with turning the steering wheel. The effect of bumpsteer is for the wheel to toe-in or toe-out when the suspension moves up or down. This toe change or “steering” occurs any time the suspension moves, whether it is from body roll, brake-dive, or hitting a bump in the road. Bumpsteer is undesirable because the suspension is steering the car instead of the driver.
Steeda Billet Camber Adjusters - '05-'09 Mustang-- Part #555-8096
RETAIL - $209.99 ; SALE PRICE - $139.00 + Shipping
Steeda's beautiful CNC machined billet camber adjusters allow for consistent, easy camber adjustment on S197 Mustangs. Unlike cheap camber bolts, these plates allow for a much larger range of adjustment and remain consistent under load. Camber bolts will tend to "walk" under loads changing your alignment settings and producing inconsistent handling and tire wear. Our plates will hold their alignment settings under any load or condition. Our plates allow you to add positive camber to reduce tire wear or negative camber for racing. Camber is easily adjusted by changing camber shims provided with the kit once installed making them perfect for quick camber changes in between rounds of competition.
Steeda's plates are made out of 7075 billet aluminum, not 6061 like the cheap copy cats and have the highest range of adjustment of any system currently available. Don't settle for anything less, buy the best today!
Steeda Billet Rear Lower Control Arms - 05-09 #555-4405
RETAIL - $379.99 ; SALE PRICE - $239.00 + Shipping
When only the best will do, say it with billet! These billet rear lower trailing arms replace the stamped steel OE parts, and depending on your desired performance goals are available with urethane bushings or a sperical bearing/urethane bushing combination for high horsepower applications.
These lightweight yet super strong arms reduce un-sprung weight and eliminate wheel hop. Steeda was first to market with these control arms and had them on the shelves even before the 2005+ Mustang was released thanks to our exclusive technology transfer program with Ford Motor Company. Steeda was the first to incorporate the proper design rear offset for the rear lower trailing arms.
Don't be fooled by other companies claiming to be first with this offset, yet they have only had their arms on the market a few months! Steeda's exclusive polyurethane bushing package also ensures smooth, quiet operation combined with performance. No increase in NVH (noise, vibration, harshness) with our poly bushings like competitors arms. Part number 555-4406 with a spherical bearing on one end and our exclusive poly bushings on the other is recommended for high horsepower applications and will only have a slight increase in NVH over the standard polyurethane bushing arms.
Steeda Sport Shifter Assembly - GT ONLY - '05-'09 - #555-7306
RETAIL - $199.99 ; SALE PRICE - $129.00 + Shipping
The Steeda Sport shifter is far superior to other competitors offerings and very competitively priced! This shifter has a revised pivot ratio that gives you short throws while maintaining a comfortable reach. Comes with a billet aluminum top plate that features adjustable shifter stops to prevent transmission damage from over extension of the shift handle. This feature is not found in any of the current competitions offerings. Nickel-plated lever provides smooth shifts and longevity. Install with our improved urethane bushings (sold separately) for even greater control.
Steeda Tri-Ax Shifter - GT - '05-'09 #555-7305
RETAIL - $289.99 ; SALE PRICE - $199.00 + Shipping
The newest Tri-Ax Shifter from Steeda Autosports is designed expressly for the S197 Ford Mustang GT, with a style that is reminiscent of the venerable "Top Loader". Yet by incorporating 20 years of race-proven technology, and by utilizing modern materials and machining techniques, this cog-swapper is right on the cutting edge!
Like the tens of thousands of Tri-Ax shifters that came before it, this Tri-Ax carries over many of the same great features like an extremely short throw, precise action, stop-bolts to prevent damage to the transmission and linkage under hard usage, our two-position handle height, and internal spring tension to assist you in never missing 3rd gear! This last feature is exclusive to the S197 Tri-Ax and not found in any other S197 shifter! The factory steel mounting rail is replaced with a substantial billet beam for more positive location; and upgraded bushings are supplied to further reduce deflection under hard shifting. Base, handle and beam are all CNC machined by Steeda from 6061 Aluminum.
Often imitated but never truly duplicated, get the original and best line of short throw shifters for your Mustang!
Steeda Charge-Motion Control Plates - '05-'08 #555-3125
Steeda Charge-Motion Control Plates - N2O - '05-'08 # 555-3126
RETAIL - $319.99 ; SALE PRICE - $225.00 + Shipping
Steeda's patented CNC machined billet charge motion plates are a superior upgrade for your Mustang. As used on Steeda's Q335 Mustangs, Steeda's plates are .070 larger than the O.E. plates and are a better port match to the intake manifold and cylinder heads than the original plates, reducing turbulence and improving airflow in the intake path for more horsepower and torque!
Beautifully CNC'd machined out of 6061-T6 aluminum for superior strength and light weight. Steeda's charge motion plates are available with tapped nitrous fitting holes for custom nitrous applications. Steeda's charge motion plates require computer recalibration for use which is available with Steeda's Xcalibrator2 or Steeda Predator tuners! Once tuned charge motion plates will not sacrifice any low end torque and provide midrange and upper rpm horsepower and torque increases. Peak increases of 10 horsepower or more have been seen on naturally aspirated applications, larger gains possible on supercharged engines
Bolt them on now and maximize your power curve today!
[FONT=&quot]
[/FONT]
Steeda Heavy Duty Engine Mounts - '05-'08 #555-4005
RETAIL - $229.99 ; SALE PRICE - $145.00 + Shipping
The weakest link in your drivetrain may be the hydra-mounts used for mounting the engine. While they get the damping job done, they can be prone to fatigue, sagging and/or leaking even with only limited hard use. These direct replacements eliminate the hydra-coupling, and do a better job of directing your engine's efforts to the wheels as well as maintaining proper engine/driveline geometry. Supplied with with two sets of bushings with different durometer ratings, making it a very versatile kit for street or race use.
Steeda S197 Underdrive Pulley System - '05-'09 #555-3305
RETAIL - $249.99 ; SALE PRICE - $169.00 + Shipping
Steeda's is the leader in underdrive pulley design for the 4.6L engines. Steeda was the first to achieve SFI approval on our underdrive pulleys for all 4.6L engines. Our underdrive pulleys are the only pulleys engineered through our unique partnership in Ford's technology transfer program to have the proper torsional vibration dampening characteristics for your 4.6L engine. No other manufacturer can make this claim.
Dont be fooled by other manufacturer's and their "state of the art" process claims. Steeda uses the latest technology directly from O.E. sources. Steeda's crank pulley is a one piece nodular iron, injection molded rubber design. Not a cheap "piggyback" design like many of our competitors use. Special rubber materials were chosen for their ability to absorb the torsional vibrations and their ability to withstand underhood temperatures. Steeda's underdrive pulleys slow down accessory speed by about 25% reducing parasitic acccessory drag on the engine. This drag reduction results in an increase of up to 10 horsepower and increased gas mileage!
Get back the horsepower and torque your belt driven accessories steal and start enjoying better performance and gas mileage today!
Steeda Upper Radiator Cover - Polished - '05-'09 #555-0633
RETAIL - $99.99 ; SALE PRICE - $55.00 + Shipping
Upgrade the appearance under hood with a Steeda Stainless Steel Radiator Cover. Choose the brushed or polished version - each is supplied with a tube of silicon for a simple, tool-free installation!
Steeda Cold Air Velocity Intake - 2005+ Mustang V6 - Part # 555-3124
RETAIL - $259.99 ; SALE PRICE - $200.00 + Shipping
Gain horsepower and torque with this straightforward upgrade. Lifetime filter can be cleaned and re-oiled, but the big news here is that we've streamlined the airflow in the 05 Mustang to the point that a computer re-flash isn't just an option, it's required!
The kit is supplied with a stainless steel air box with built-in velocity stack and CNC billet aluminum mass air meter. It mounts in the factory location with the supplied rubber trim to seal it against the hood & fender to keep the hot air out. Our tests showed inlet temps a mere 10 degrees above ambient temperature. The Steeda Lifetime Filter can easily be cleaned and re-oiled, making maintenance a snap. All hardware required for installation is included in the kit.
We've found between 16 -20 more rear wheel horsepower with this kit.
email [email protected] or call 313-561-5500 ex. 2123 with any questions.
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
