Musmaro
If you want more info or pics of anything, just ask. I have more I'll add from time to time, I can't remember it all. Everything is open to offers, trades + cash.
Mustang
Fox Body Harness Bar w/RJS Harnesses
Fox Body Mustang GT Ground Effects
Fox Body Tilt Column w/ignition & key
Fox Body Clutch fan, shroud and coolant reservoir tank from an 86 GT
Fox Body Gas Door
Fox Body Washer Fluid Reservoir with pump from 84 LX Vert
Fox Body Wiper Motor
Fox Body Wiper Arms with Wipers
Fox Body Door Panels, only one armrest, pass. panel has hole cut for manual window
Fox Body dual knob radio with antenna, power booster(amplifier) with complete wiring harness from 84 LX
Blue Seats from 84 LX, no rails
84 Mustang LX Steering Wheel
Navy Blue OEM 83-86 Hood
Rust Free Fox Body driver's side Fender(very dark blue, almost black)
Blue Anodized SBF Valve Cover Bolts
Stock EFI Intake, upper and lower from Fox Body, Explorer TB
2 Stock Water Pump Pulleys and a Stock Crank Pulley
Several Stock Starters and Solenoids
302 Motor Plate
5.0 HO FI Distributor
Stock 86-93 5.0 Headers
7.5" Rear End with driveshaft(not sure on gears, came from an auto 3.8 84)
Cut LX Fox Body rear springs
86 Mustang GT Gauge Cluster
Front red calipers, newer pads from an 86 GT
Like New Master Cylinder with <500 miles(was on an 86 GT)
Power Brake Booster, lil rusty from an 84 LX(also have the master cylinder from this car)
Set of Brand New Russell Speed Bleeders(for disk front, drum rear)
Brand new in package FOMOCO black antenna
Most of the interior from an 84 LX(except door panels/dash)
GM
GM 5 Lug Chrome Wagon wheels w/nice tires, one leaks...leak is marked with paint marker, easy fix
T5 Black Ball Style Shift Knob
4th Gen Camaro Rear Seats & Cargo cover(Grey)
Full set of steelies w/tires and stock 4th gen hubcaps
Third Gen Camaro Rear Bumper + Z28 side skits
82-92 Camaro Spoiler End, driver's side...red
Full set of Third Gen Camaro Centercaps, 2 missing Camaro emblem
4.9 Caddy TBI Cover(Part of the air intake, perfect carb hat for a turbo or CAI setup, already modified to fit a carb)
305 TBI Coolant Temperature Sensor and Throttle Positioning Sensor, used but in working condition
Holley Aluminum SBC Valve Covers(old style)
4th Gen Camaro V6 master cylinder w/ABS unit
86 Camaro Gauge Cluster(use for parts lense is broke)
305 Flexplate from third gen F-Body
Third Gen V8 F Body Muffler Setup(single inlet, dual outlet)
73-87 Pickup Chrome Drip Rails
3100 Valve Covers
Purolator Air Filter, fits most 2.2/4.3 vehicles, was bought originally for a 94-up S-Series NIB
Fiero
short shifter assembly w/knob
2.5 Cylinder head off an 84
2.5 Distributor w/brand new ignition module from an 84 aswell
Brake Master Cylinder, lower miles in excellent shape
non-power center console plate
non-a/c climate control
White Hood with headlight door
Set of 84 base White Fenders
Sunroof w/Latch
Universal
Easy Street Dual Needle Pressure Gauge, got two..one has cracked face
Lighted Toggle Switch, NIP
Sunpro Volts Gauge NIP
MSD Blaster 2 Chrome Coil
Aluminum Quadrajet to Square Bore 4 barrel adaptor/spacer
JVC RM-RK31 Remote
Bazooka 6.5" Grilles
Lots of gas caps
215/50R17 Hankook Ventus HR2 tire, Plenty of tread left
Lexani Roma, chrome 17x9, great shape, only one
Primax 772 16x7 5 lug wheels, need refinishing, set of four
Super Sweet "S" Type White/Black Seat Covers
Other
NGK TR55-1GP Plugs(6) NIB
Champion RS10LC Plugs(4) NIB
STP S8873 Oil Filter NIB
V6 SHO Airbox w/K&N in it
00-04 Focus Motorcraft Air filter NIB
Stealth/3000GT Airbox, no filter
Stealth/3000GT Upper Intake Gasket NIB
96-98 Grand Cherokee Chrome Grille
420a Upper Intake Gasket, NIB
420a Misc. Front Oil Seals NIB
420a Head from 97 Talon(timing belt broke)
Complete set of 14 inch 97 Cavalier hubcaps
Random Plastic Charge Pipe w/BOV(BPV)
Parting out 4.0 XJ in red, PM me with your needs
Also parted out a 81 Datsun 280ZX, 95 Del Sol SI and a 85 CRX DX, PM me for your needs
Will consider trades for:
Honda Parts(EK, D-Series, 1g CRX/Teg parts)
Fox Body parts
5.0 parts
Nitrous crap
Wheels and Tires
Firearms
Computer parts
Electronics
Furniture
Appliances
AT&T Phones
Anything else that may interest me, open to pretty much anything. <3 Trading. Also, I accept Paypal and will ship if needed.
Some pics can be found here, will get pics of anything else. Everything in this album is for sale. http://s21.photobucket.com/albums/b291/Musmaro13/Stuff For Sale I will add more as I find/remember more.
Some of this stuff has been listed on eBay and more will be periodically: http://shop.ebay.com/deblouw2006/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Mustang
Fox Body Gas Door
302 Motor Plate
GM
3100 Valve Covers
Fiero
Sunroof w/Latch
Universal
JVC RM-RK31 Remote
Lots of gas caps
Other
Fox Body parts
5.0 parts
Nitrous crap
Wheels and Tires
Firearms
Computer parts
Electronics
Furniture
Appliances
AT&T Phones
