Some Connector Help
StockNotch
The car: 89 Lincoln Mark 7
The story:
I had to move part of the main engine harness in the car, in order to make room for the charge piping. Two connectors (above the smog pump, connecting the harness from the wheel house to the main harness that runs along the frame rail) were almost impossible to get separated but, they finally did. Once apart, I noticed they're toast. What connectors are these/what do they do? I have Googled but, have not found anything as most images stop before these connectors.
The pictures:
Sorry for the horrible cell phone pictures.
Time for some snips!!!! If nobody else chimes in, I'll check the evtm at work tomorrow.
These are located near the ps pump and ac compressor on the driver side? near the fender apron? From what I can see, they look like connectors 102 and 106. So far, I can see that the egos run through 106. Oldest book I have is 92 so thats what im going off. Ill see if I can dig through a little bit more.
Passenger side, the harness runs through the wheel house then, inside the engine bay through the hole just behind (when looking from the front of the car at, the fender apron) the factory air box then, plug into the main harness right above the smog pump.
I did find this picture this morning, I'll have to check the colors when I get home tonight. This is from a Mustang so, I am not 100% sure it will be the same.
Going off that, I'd say Fuse Link M
The last picture I posted (i'll get a better one when I am home) shows the location. Right by the tower above the smog pump.
These plugs come off of the harness that come from out side of the strut tower (it has the test plug and such on it (not labeled on the picture) and, plugs into the main (harness that runs down the frame rail) right by the strut tower.
