Small Block Ford Original Buddy Barr/Holley tri-power set up
rockher_man
Early 60’s Factory Ford 3-deuce Buddy Barr/Holley tri-power set up... $2500.00
Life got in the way and had to sell my project.....:icon_mad:...now I have no use for this stuff and need
to get my investment back for other projects...
ORIGINAL and ready to run Early ‘60’s Factory Ford 3-deuce Buddy Barr/Holley tri-power setup!
KILLA LOOKS & BADASS nostalgia at it's best...
Off of a running mustang, This is a small block Ford set up, originally offered for 260/289 V8's;
.. everything you see in the pictures is included!
VERY RARE!!!
ORIGINAL and CORRECT primary & outboard carbs verified by Holley!!!…Matching set!…VERY
difficult to find all THREE carbs for this set-up still together and working perfectly!
Carb's are smooth operating and linkage works great...
The outer carb's are list #2868 are both rated @ 265cfm and EACH dated 392.
Build Date; 1963,Sept.-2nd week
265-cfm each
The center carb is list #2867 is rated @ 200 cfm and dated 391.
Build Date; 1963, Sept.-1st week
200-cfm
TOTAL cfm = 200+265+265= 730 cfm
PERFECT for a HOT street Stroker, nostalga rod, gasser, or go-fast boat!
According to info. I got back from Holley...these were listed for '63-'64 (and MAYBE 1965) Comet, Fairlane, Falcon and Cobra's with small block 260 c.i. (and 289 c.i.) V-8 engines.
TOTAL cfm = 730
Holley supplied the proprietary 2300 "G" carb's. for tri power use ONLY! Buddy Barr cast the
intake for Ford.
The standard single parts like jets, power valve, bowl screws, squirter, pump, cams, etc. are still available from Holley...oval filters available from K & N and others...
-rebuild kit is #3-888 for both carb's.
This factory CORRECT setup includes both original fuel rail and original progressive
throttle linkage, the air cleaner base looks to be factory original also, the ''COBRA'' lid looks
good and fits well, just bolt it on and GO!!!
I will include three HOLLEY rebuilt kits and three custom fabricated 1.5" carburetor spacers!
Also includes an original MOON fuel block...NOT a repop...
Also includes a Tri Power emblem in red-white-blue! .
..I was gonna grind down some of the raised ribs and tack this to the Cobra lid...
Tri Power Emblem.jpgSBF Tripower.jpgSBF Tripower_a.jpg2300 series carb isolators.jpgMOON fuel block.jpg
Dearborn MI. area...Call Brian with any questions @ 734-536-2745
