Siemens DEKA I 83 lb / hour Low Impedance Injectors
90blknotch
Just bought these but ended up getting a deal on some bigger ones. They were not on a street car and have very little use. These will work with an after market EFI like a FAST or Big Stuff 3 but will require and injector driver mod (or standalone box) to work with most factory computers.
Specs:
Coil Resistance: 2.35 Ohms / Low Impedance / Low-Z (Peak/Hold driver circuit required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 86.2 lb/hr = 888 cc/min = 652.2 g/min
Connector: Bosch EV1
Spray Pattern: Pencil
Siemens FI11405 ( 3105 )
Looking to get $300
