SBF Parts For FOX Body Mustang 5.0L
Big Shot NOS system 150 to 300 shot - you will need switch and bottle hold down - this includes the 10lb bottle, ss line, plate with soilends, for EFI Cobra Intake. $450.00
Radiator fan Shroud w/ overflow bottle used $20.00
AC Compressor and Condenser used $25.00
AC Compressor Bracket used $20.00
Power Steering Pump Bracket used $20.00
Alternator Bracket used $15.00
Smog Pump Bracket used $10.00
Belt Tensioner used $20.00
Smog Pump used $10.00
Heater Core Assembly with all plastic ductwork (entire assembly from underneath dash) $50.00
Stock throttle body used $20.00
Stock EGR Spacer used $20.00
Stock Upper and Lower Intake used $100.00
Stock E7 Heads used $100.00
SBC Parts
350 SBC 010 block with small 1/2" crack in lifter valley - stock bore block has been cleaned and magnafluxed. Crack can be fixed by machine shop for about $150.00. Easy fix for someone. $65.00
350 SBC heads - Stock - $55.00
350 SBC Crank - Stock - $45.00
Misc. SBC parts - rods, intake, carb, etc all for $50.00
AMC Parts
AMC 360 block $50.00
AMC rods/pistons, alternator, flex plate, and timing cover - $25.00 for it all
BBC 454 Gen V Block. N.O.S Brand new. Needs to be finished honed only. $800.00
Blower Parts
Have a 6-71 blower with carb plate, pulley and tensioner but no intake manifold. Used. Rotors still in good condition. $900.00
Dodge Neon spare tire $25.00
Dodge Neon Dash Pad $10.00
Dodge Neon Front brake calipers $10.00 both sides
Dodge Neon stock fuel rail $10.00
Dodge Neon SRT4 stock front and rear swaybars $35.00 each
Dodge SRT4 and Neon Misc Prothane swaybar links NEW STILL IN BOX $8.00 Each
Dodge Neon SRT4 Stainless Steel Brake Lines NEW STILL IN BOX $75.00
Dodge Neon SRT4 cold side intercooler stock rubber pipe w/ sensor $30.00
Dodge Neon SRT4 Front bumper beam $15.00
Dodge Neon and SRT4 Rear Tension Struts NEW STILL IN BOX a high-durometer bushing material designed for heavy-duty and competition use. The revised design results in improved toe stability (reduced bump-steer),which virtually eliminates rear wheel hop under heavy braking.Provides more positive suspension control for improved driver feedback and dynamic stability. $40.00
Trans parts
Turbo 400 trans..good core needs rebuild $80.00
Trubo 350 Trans..Good core needs rebuild $65.00
Will trade parts for SBF parts for FOX body and 99-04 Mustang parts.
SBC Parts
AMC Parts
Blower Parts
Trans parts
