SBF Parts For FOX Body Mustang 5.0L
Used GT40 Iron Heads w/ roller rockers $400.00
Big Shot NOS system 150 to 300 shot - you will need switch and bottle hold down - this includes the 10lb bottle, ss line, plate with soilends, for EFI Intake. $500.00
Clutch fan only used for 50 miles $20.00
Radiator fan Shroud w/ overflow bottle used $20.00
AC Compressor and Condenser used $25.00
Smog Pump $10.00
Heater Core Assembly with all plastic ductwork (entire assembly from underneath dash) $60.00
SBC Parts
350 SBC 010 block with small 1/2" crack in lifter valley - block has been cleaned and magnafluxed. Easy fix for someone. $75.00
350 SBC heads - Stock - $65.00
350 SBC Crank - Stock - $65.00
Misc. SBC parts - rods, intake, carb, etc all for $100.00
AMC Parts
AMC 360 block $75.00
AMC rods/pistons, alternator, flex plate, and timing cover - $30.00 for it all
454 Gen V Block. N.O.S Brand new. Needs to be finished honed only. $850.00
Blower Parts
Have a 6-71 blower with carb plate, pulley and tensioner but no intake manifold. Used. Rotors still in good condition. $1000.00
Dodge Neon spare tire $25.00
Dodge Neon Dash Pad $15.00
Dodge Neon Front brake calipers $15.00 both sides
Dodge Neon stock fuel rail $10.00
Dodge Neon SRT4 stock front and rear swaybars $35.00 each
Dodge SRT4 and Neon Misc Prothane swaybar links NEW STILL IN BOX $8.00 Each
Dodge Neon SRT4 Stainless Steel Brake Lines NEW STILL IN BOX $100.00
Dodge Neon SRT4 cold side intercooler stock rubber pipe w/ sensor $50.00
Dodge Neon SRT4 Front bumper beam $15.00
Dodge Neon and SRT4 Rear Tension Struts NEW STILL IN BOX a high-durometer bushing material designed for heavy-duty and competition use. The revised design results in improved toe stability (reduced bump-steer),which virtually eliminates rear wheel hop under heavy braking.Provides more positive suspension control for improved driver feedback and dynamic stability. $40.00
Trans parts
Turbo 400 trans..good core probably needs rebuild $100.00
Trubo 350 Trans..Good core probably needs rebuild $75.00
Smog Pump $10.00
SBC Parts
AMC Parts
Blower Parts
Trans parts
