s10 power brake to manual brake
stroked10
ok so i took my booster off now when i go get the manual brake plate will it have the rod on it that goes to the brake pedal?.
the rod is not part of anything else, your best bet it to hit a junkyard looking for the plate, and grab the rod at the same time
right i was going to but the rod off the back of the booster that connects to the brake pedal.will that be off the back of the plate for manual brakes.i think it will im just checking.basically i go to parts galore and take the plate and the little rod that goes into the master cylinder and im guess the plate will have the other rod on it like the booster does i have a pic.
no, on manual brake trucks the rod goes from the pedal to the master, the plate just mounts the 2 bolt master to the 4 bolt firewall
ohhh ok sweet thats what i needed to know sweet thank you.so i can take the old one out of the booster and cut to lenght and make a plate myslef ok thats sweet.
heres my booster i can use that rod and fab it up or get one from parts galore.do you know anyone that would want this booster.
