s10 4 wheel disc brake converion
stroked10
Ok I have a 93 s10 it originaly had disc brakes on front drums in the rear.I took the booster off and put a manual brake plate on and rod.well I have willwood dynalite pro series brakes all around.what else will I need to change.there's 2 blocks under the booster are those proportioning valves or metering blocks.do they need to be changed or anything since its 4 wheel disc brakes now.
