r6rider2002
amp works great was only used for a few weeks and retails for around $400 i have no use for it call anytime. $125
Jay
(586)859-9473
Rockford Fosgate's high-tech solutions yield more power
Power Series amplifiers actively monitor their speakers' performance using Rockford Fosgate's Constant Power technology. A speaker's impedance naturally fluctuates as it performs. So, just like your cruise control increases the engine's RPM to maintain your car's speed uphill, Constant Power maintains this amp's output by increasing its internal voltage and current when the speaker's impedance rises. This results in up to a 25% increase in the amp's total power output, especially in the crucial range below 50 Hz where a sub amp really has to shine.
Rugged construction, massive bass
Rockford Fosgate builds each Power Series mono amplifier with heavy-duty, state-of-the-art components. The award-winning Dynamic Thermal Management design manages the temperature of the internal components, distributing heat evenly for higher efficiency and lower distortion. The unique heat sink allows the heat to escape more readily so the high-power output transistors stay cooler and last longer
Details:
mono subwoofer amplifier
300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
500 watts RMS x 1 at 1 ohm
CEA-2006 compliant
Dynamic Thermal Management cooling system
variable low-pass filter (35-250 Hz, 24 dB/octave)
selectable subsonic filter (28Hz, 24 dB/octave)
variable bass boost (0-18 dB at 45 Hz)
optional wired remote bass boost
Class-BD amplifier design
MOSFET power and output stages
preamp-level inputs and outputs
4-gauge power and ground leads and an 100-amp fuse recommended — wiring and hardware not included with amplifier
no onboard fuses — when installing multiple amps in a system, an additional 100-amp in-line fuse between the distribution block and the amplifier is recommended
11-7/16"W x 2-1/4"H x 8-15/16"D
Jay
(586)859-9473
Details:
CEA-2006 compliant
