Turbodan
Saturday I was driving home and the check engine light came on. Got home and parked it. 3 hours later got in it and would not start. Borrowed a scan tool and got a Crank sensor error. I disconnected the battery and then climbed underneath to install a new sensor. Reconnected the battery which cleared the engine light. Tried starting it. Would not fire up. Does not seem to be getting spark from the coil. No check engine lights have come up. What should I do/replace next? This is on a 1999 with a 4.0. Is there fuses or relay fuses that might cause this.
