dave89iroc
Where does everyone recommend to get reman heads or get heads gone through?
Well, it won't be right away, probably in a month or 2, but my truck burns oil like crazy on startup and if idling for a while, none on accel, so I'm sure it's valve seals/guides, and I'm burning coolant, hopefully just gaskets, but would want the heads checked .......it's a 2000 chevy 4.8lI do heads. what are you looking for?
Yeah, I've used him in the past, a few jobs left a bad taste thoughGreg's Cylinder Heads in Riverview. But you probably already knew that being from Downriver.
yeah I would pressure test those for sure before doing anything to them. Seen many crack across the top near the head bolt holes. Don't see to many bad guides in them more then likely just seals but you never know.
Im at Automotive Machine in fraser let me know when your ready
