rear main seal help
brandon48080
i have a 302 block with 347 stroker kit , heads, cam blower , and im leaking oil from my rear main seal does any one know how hard it is to fix thanks
If the block has a one piece design seal you will have to pull the trans. and flywheel. If it is a 2 piece design you will have to pull oil pan. What year is the block?
Tom
remember to put some oil on the seal before you bolt it all together so the new seal doesnt fry on startup
