rear control arms!
85notch said:
Can't find a good used set yet so I might have to buy new ones! Any suggestions?
It depends on what you are doing with the car. If you are primarily drag racing the car and street use (basically care about straight line stuff). Here are the ones I would suggest:
(All of these would be of the adjustable or double adjustable nature, rod-ends, delrin bushings, etc.)
1. TRZ Motorsports
2. Wolfe Race Craft
3. Team Z
4. Skinny Kid
call teamz and tell dave that i told you about it, he might give you a break..he usually helps me out whenever i get parts from him...
x2 dave is a great, standup guy you cant go wrong when u go to him
If it is not a track only car try HPM Mega bite Jr. lower and double adjustable upper from UPR with urethane bushing in the body side. Less noise when driving on the street and are not as hard on the torque boxes. Will work great at the track also. I use to run these on my car.
PAUL WILEY
