r6rider2002
I have a used 2001 ras turbobend cnc folding system it only has 2,900 hours on it its barely been used its in great shape i own 2 of these and this one never gets used i dont have enough work for both this is my only reason for selling it. call anytime $25,000 obo
(313)893-3550 from 8am - 4:30pm
(313)363-4897 after 4:30pm
Pics Here:
http://detroit.craigslist.org/mcb/tls/1736448799.html
EQUIPPED WITH: RAS CNC SYSTEM 5000 for Backgauge, Folding Beam, Upper Beam, and Virtual CNC Axis for the Folding Beam Adjustment, All Welded Steel Construction, 3-1/2" Floopy Disc Drive, Foot Pedal.
NOTE: The RAS Turbobend is the Fastest and Most Accurate Metal Folding System for the Roofing, Architectural, and Metal Contruction Industries. The RAS Turbobend is a Very High Quality German Built Machine w/ an Extraordinarily User Friendly Control! New Replacement Price is $ 155,000.
CATALOG SPECIFICATIONS:
Working Width......................................... 124"
Maximum Sheet Thickness............................... 16 Gauge
Minimum Inner Bend Radius............................. 1.5 x Thickness
Minimum Flange Height Inside.......................... 6 x Thickness
Maximum Upstroke...................................... 4.72"
Maximum Floding Beam Adjustment....................... .19"
Backgauge Depth....................................... .31" - 39.4"
Working Height........................................ 33"
Downstroke Speed...................................... 2.5"/second
Maximum Folding Beam Speed............................ 80 Deg./second
Backgauge Speed (.31"-30.4").......................... 1.9 Seconds
Electrical System .................................... 220/3/60
Approximate Machine Dimensions........................ 170" x 56"
Approximate Machine Height............................ 55"
Approximate Machine Weight............................ 5,500 Lbs
Pics Here:
