Random SN95 Parts.
Roushy
I'll start with Various wiring harnesses, if that's how you spell it. I have a complete engine harness. Trans harness, a convertible top wiring harness, front end harness etc.
I have a CPU with a Diablo chip inserted. The chip was tuned to a set of GT40Y heads and GT40 intake with 24# and 76mm MAF.... If that helps. $100
95 T-5 bellhousing $25
Flows with tips but they are welded. Brand spanking new flow tubes. all 2.5in. tips are not polished. $150
95GT hubs and spindles (5 lug). 90k and in great shape, ready to mount up. brakes too. Stock GT stuff not 13in cobra or anything. $200 w/o brakes
2 core Aluminum rad. Full aluminum, no plastic sides. OEm fit $125
Solid K member with A arms. Ball joints are questionable. Make an offer
Stock 95 GT 17" rims with 275/40s enough tread to roll around on, not bald but at the wear bar or below. $200
Black Air bags. $100 drivers $100 Passengers...... let me know if I'm way off here.
8.8 with 3.73 complete disc to disc, would go great with spindles and hubs for 5 lug swap. Gear was installed about 25k ago (6 years). $400
Motorsport Aluminum clutch quadrant and cable. The bolt end that hooks to pivot arm has some rust. the quad is super clean, not much to get dirty. $40
Convertible hyd. pump and cylinders with lines, 100% complete, all good seals and such. $250
I have 2 leather shift boot covers. One black, one tan. the cig lighter mounts are slightly different between the two so I think one might be from a 98 or higher. $10 ea.
Leather cobra shit knob, good shape. $15
Clean black decklid with wing. $100
I have more useless stock shit like ccrm bracket and module, colant resv. stock elec fan, power mirrors, vert rear view mirrow, mach 460 with radio and cd player (all speakers too).
I'll take requests.
can i get some pictures of what the piece of the harness that plugs into the ecu looks like? i need to steal wires out of this one for a fox if the pins are the same kind
do you know what brand the radiator is?
And do you happen to have the black cowl piece that goes between the hood and the window? Mine has a few broken tabs.
I knew I would botch up something somewhere. I was ass draggin tired when I wrote that out.
Cowl is gone
Shift knob is nice
rad is a Mishimoto.
