igotaneed4speed
Lets hear some pump gas numbers from you turbo guys if ya got'em..
list a basic eninge cubic inch and turbo set up
With or without alky injection?
Roughly speaking any engine with a decent cylinder head and compression around 10.0:1 with a proper camshaft will take about 10-12 psi of boost on 93 fuel.
what are you building ?
guy in canada made 920rwhp/820rwtq with a 347 ls1 with a F1R through a 4l65E on pump gas and meth in a z06
And got in a wreck on the way down from Norwalk before he could make a pass with the Vette guys. Then there was the Damn food poisoning incident too. grrrrr hahaha.
Rick,
A engine, I was just looking for a comparative..
It's way under 10.0 has a custom cam, and decent heads. The goals 800 + on pump with injection.
It'll be tight bt you might be able to pull it off. Care to share some engine specs. what gets tough is getting beyond doubling the output of the engine with pump fuel and Meth injection.
Sean
Im hoping for around the 1000 hp mark on pump gas.. Only a couple more weeks and the car will be on the road..
Are you going to go with bigger turbos like you mentioned on aim baldie?
