502SS
Ok, here's what I have for motor...
383 Small block chevy
Callies crank
Carrillo 6” rods
JE/SRP pistons (10.5-1 compression)
Comp Cams custom solid roller (.571/.577 lift)
Comp Cams lifters
1.5 rollers with stud girdle
AFR 195 heads
Edelbrock Super Victor intake
Pro Systems 780 carb
MSD 6AL
MSD Dist/coil
What I added this year...
NOS Cheater kit with an HVH plate and 150HP jets in it.
MSD retard/start box
Everything is the "out of the box" setup
Max I want to run is 180HP, but the 150's are in it (not sure if the 180 would make that much of a difference?).
I REALLY want to run pump gas if possible on the bottle. What are some thoughts here? If it's feasible, how much timing do I need to pull? It has 38* total right now (not locked out, it's all in by 1,500RPMs). What plugs/etc. should I run? Any other info I should know?
Keep in mind this is in my Jeep, so the runs take place at the sand dragstrip. The tracks are 300'. The MAX I might run would be 400' at the dunes, so for the most part, I'm on the bottle for 5 seconds or so at the very most (usually mid 4 seconds).
Callies crank
Carrillo 6” rods
Comp Cams lifters
AFR 195 heads
MSD 6AL
MSD Dist/coil
