BaggedCereals
New member
I have a 89 F-150 with the 5.0 and a 5sp.
The truck runs and strats but dies 30 sec later. It was loosing spark so i changed the cap, rotor, pickup coil, coil, module on the distriutor, ECC relay and fuel filter.
Now its keeping spark but still dying. I think its loosing fuel now! I can hear the high pressure pump kick on but im not sure if the low pressure one in the tank is bad?
what should i do? where to start? Should i change the fuel pump relay? fuel pressure regulator?
Anyone had problems with these old pickups?
Thanks!
Thanks!
