Speedy
Bought this and never ended up using. It's Model number BN138
Here is Porter Cables details on the gun
Long life maintenance-free motor to keep from staining the work surface
Internal piston catch for consistent max power on every shot
Rear exhaust to keep contaminants away from work
Drives 18 ga. nails from 5/8" to 1-3/8" length
Tool-free depth-of-drive adjustment with detents for proper setting of nail heads
Tool-free jam release mechanism for easy nail removal
Sequential style trigger with lock off switch
Removable non-marring nose tip with on tool storage
Contact safety located behind driver guide for better visibility
Adjustable belt hook
Integrated rubber grip for improved comfort
Low nail reload indicator
Special hardened driver blade
Strong, lightweight, die-cast aluminum housing
First $50 takes it
(586)524-353zero
Mike
First $50 takes it
(586)524-353zero
Mike
