Rubbernuts
PE 4600 2 stage fuel injection race pump. Works very well, gonna go belt drive pump. Has new seals, pretty sure I have another seal kit too, I will give that with the pump also. Used for 3 seasons at local track one-two times a month, very good condition. 517-605-0373, text is best, I can send pics. Will leave fittings in it also. $150 shipped or can meet up some where within reason.
Thanks, Scott
230 Gallons per hour @ 100 PSI
60 - 115 PSI (pre-set) (approx. 100 PSI max @ 12 Volts; approx. 115 PSI max @ 16 Volts)
(2) external -8 AN bypass (adjustable)
Cleanable filter
Alcohol compatible
Works with 12 or 16 volts
7 Vane impeller
-12 AN boss O-ring inlet & outlet ports
Continuous duty
Thanks, Scott
Cleanable filter
Alcohol compatible
7 Vane impeller
Continuous duty
